1 - 1 of 1 Posts
Hello guys and gals,
I have uncovered yet another article that I referred to when I replaced the oil pan on my old '02 Odyssey. This procedure does required the removal of the timing belt and idler pulley so it's quite involved. If any of you guys would like me to post up a DIY for the timing belt and idler pulley replacement then I will be happy to oblige ;)
Here is a quick guide to replacing the oil pan on a '02 Odyssey:
1) Drain the engine oil.
2) Set the engine at Top Dead Center (TDC).
3) Remove or disconnect the following:
  • Negative battery cable
  • Timing belt
  • Idler pulley
  • VTEC solenoid valve and oil filter
  • Oil pan bolts and the pan.
To install:
1) Apply liquid gasket to the inner threads of the bolt holes and the engine block along the area indicated by the broken line in the accompanying illustration.
2) Install the oil and tighten the bolts to 105 inch lbs. (12 Nm).
3) Install the remaining components in the reverse order of removal.
**Step shown here: Apply liquid gasket to the inner threads of the bolt holes and the engine block along the area indicated by the broken line**
**Shown here: Oil pan tightening sequence**
-Additional oil pan diagram-
*diagram courtesy of hondapartsnow.com; all rights reserved
1 - 1 of 1 Posts
