So today, as driving normally, my battery light came on. I pulled over and plugged in my scanner and it was only pulling 10v while running. Obviously the alternator stopped. Battery checked out fine, but died very shortly after, as expected. I opened the hood and the amount of heat coming from the alternator probably could have cooked eggs if it was a griddle. The smell was horrible electrical burning. I sat for an hour total, including having someone charge me for about 15 mins so I could make it somewhere. I touched the alternator at this point, which had not been running for an hour, and literally burned my finger. I got on the road and drove for the 6 miles to a family member's home. The last mile of the drive I started watching the voltage and it was in an entirely normal range. I parked and left the van running, opened the hood and, more carefully this time, touched the alternator. It was still hot, but cooling. The readings were normal. I drove the half hour home, family member behind me, and the readings remained normal the entire drive. By the time I got home the alternator was at a normal operating temperature.
If everything has gone back to normal, why did the battery light never turn off? It's still on if I go start the van right now. Does the Ody instinctively know that something is somehow still wonky?
