my 96 ody is overheating.
I replaced the temp sensor and the thermostat.
had the timing belt and water pump done as well.
the thermostat is working, eventually the lower hose heats up.
both fans come on when the ac is turned on, when I turn the car off the cooling fan kicks on, it runs then turns off then runs kind of wierd but seems to be working.
when I drive, the fan never kicks on. I'll drive 20 miles on the highway, then stop and the temp will begin to climb. I get out to look at the fan and it's not moving. if I turn the car off it will start.
when I sit in a drive through the temp begins to climb... if I rev the engine it will bring the temp down.
