P0141 (o2 sensor heater circuit malfunction, bank 1, sensor 2)
1 reading
50K views 13 replies 6 participants last post by  Boomers-Odyssey
Why not diagnose the problem instead of throwing parts at it. Did you have the Po141 code when you had the P0420? A bad O2 sensor can cause the p0420. P0141 is an O2 heater open code. Use a voltmeter or ohmmeter to check out the O2 sensor in the converter. If it started when you replaced the old one or converter chances are the wiring got screwed up. Use a voltmeter or ammeter to check it out.
