Hi! I have an 05 Ody Touring. The front passenger door is locked and won’t unlock with the fob, door switch or manual lock pull. I can’t pull the lock up. Like it’s stuck. I’ve jiggled and yanked but I didn’t want to break it. I pulled the fuse, it’s fine. It sounds like the actuator is trying to do something when I try the switch. The door is locked and can’t be opened, so now the front seat is hard use without gymnastics. I have managed to get the door panel loose which was very tricky while it’s shut. How do I manually unlock it though? The cable is in a plastic sheath like bicycle brakes and the mechanisms look to be in a white plastic housing. I can’t remove the lock assembly without opening the door to get to the 3 screws holding it in or the bolt holding the window track in place. What could be the cause? And in the meantime how can I over ride the lock to get the door opened?
