Hi,
[COLOR=#739912 !important][FONT=inherit !important][COLOR=#739912 !important][FONT=inherit !important]I[/FONT][/FONT][/COLOR][/COLOR] have a 2000 Honda Oddyssey. The passenger side door is not able to close as the side slider will not latch on the back to the door. The little plastic that is in back of the door is stuck and will not turn back for the door to latch. I was 'messing' around with another issue and turned the plastic side slider all the way inside. Now the passenger door will not close as the plastic is in the way. Pictured attached will give a better picture. I have tried to pull the handle from inside and outside but the plastic will not move. I don't have a better name for it but hope the picture makes it clear. Hoping this is an easy fix and I don't have to open up the entire door assembly...I have tried WD-40 and all kinds of greases..Thanks all.
