The passenger front door wont open from the inside, but works fine from the outside, was wondering if anyone knew the issue or how to fix it? the window also doesn't work on that same side. Related?
Probably unrelated. Likely a cable failure from the interior handle to the latch. The window, assuming it appears to still be on the track is likely the window motor. It's not terribly hard to pull the door panel. Just had my drivers door panel off to do the door lock actuator.
Does the resistance of the door handle feel the same as the driver side when you try to open it? There is a rod that is connected to the inner door handle, and it might have come off for some reason. You can check that without removing the door cover. See this video on replacing the door lock actuator to see the components of the door mechanism. At 1:55 he refers to the rod connected to the inner door handle. At 8:00 you can see where the other end of the rod connects to the door latch mechanism, where the door cover has been removed. One of those two locations has likely come loose.
