As you can see from the pic below, the passenger side door handle seems to be separating from the door. The handle works but it needs a firm pull to actually open the door. I took the door panel off and checked from the inside and the bolts in there are pretty tight. I am not thrilled about the prospect of replacing the door handle. Even if I don't screw up the install I will still be left having to paint it since all the handles I can find online seem to be unpainted. Any suggestions?
Footwear Shoe Leg White Black
This^^^
assuming the fastener came loose or is broken off from someone going gorilla on a plastic door handle.
The side that is lifting is the one on the right side of the handle in the pic.
if the fasteners just came off, they are likely in the bottom of the door, if its broken off you'll need a new handle.
yours has the sensor in the handle, they are not cheap.
Product Font Motor vehicle Automotive lighting Rectangle
