To all ... Pedal Commander is geared towards the light turbodiesel truck market (3/4-ton and 1-ton ... and even heavier turbodiesel trucks).
It is not useful for the Odyssey. What's the action we can take on VCM-"equipped" Odysseys to get rid of this lag during that brief transition from less-than-six cylinders back to full V6 capability?
its called disabling the VCM...
If you have a 2008 or newer turbodiesel truck with DEF, SCR and DPF, sequential turbos, etc., then Pedal Commander is a great product to eliminate throttle lag while "the rest of the installed gear catches up."
somebody please run a quasi-scientific test on this thing, i want one!
You don't need to test it. It's a successful product for the turobdiesel truck market.
For those of you who remember rebuilding the occasional 4-barrel carburetor (or even small foreign 2-barrel jobbies), there was that accelerator pump that allowed you to have decent throttle response until you got the smallest amount of rev increase and vacuum to let the carb "get onto the jets." Pedal Commander, from an electronic diesel injection management perspective, is analogous to that.
Personally, I've never minded easing onto the throttle, towing or not, in a turbodiesel truck and letting everthing spool up and then keeping revs reasonable to allow staying in the narrow powerband through gear changes going up an onramp...
...however, I can see where one has to navigate a cityscape all the time, with stop and go traffic, where Pedal Commander would be helpful.
