741 - 760 of 1,998 Posts
Discussion starter · #741 ·
sorry, I am new. I tried to PM @verbatim first but since I am a new to this forum, it's not possible. Anyway, I would like to see about ordering one of these. Last week, I took my 2013 in to the dealer for service and they state the oil rings collapse. service manage made a comment about eco system and this morning when I went to drop the van off, I had a chat with another service manager. Long story short, we hosed ourself on the "warranty forever" deal through the dealer and I've been researcher this issue ever since.
so I have a couple of questions:
  1. I've already replaced #4 & #3 spark plug with new plugs (the NKG), I should only have to replace the other 4 ( #1, #2, #5, & #6)?
  2. Do I need to run some sort of cleaner through the motor? Read this in one of the other threads.
  3. What questions (if any) to ask service manager when I pick up the Van tomorrow.
thanks, lots of info still to take in.
1: You don't necessarily have to but yes, you should.
2: Not necessarily. If you want, you can, but just disabling VCM can be and usually is enough.
3: None
owns 2006 Honda Odyssey EX
Discussion starter · #743 ·
This is what my #2 cylinder plug looked like compared to new. Feel pretty good I got 198k before the check engine light. Maybe always using Shell gas.
Wait a minute, so that plug was in there for 198k? That's a damn long time, wow. Almost double the plug's intended lifespan.
Reactions: dpierce
If #4 & #3 were recently replaced, just replacing the other 4 would be sufficient. However replacing all 6 would improve the chances of a full recovery (in conjunction with the VCM disabler of course).
A quality fuel system cleaner (e.g. Techron) in the gas tank wouldn't hurt.
Depending on miles accumulated since the last oil change, a load of fresh engine oil (for its detergents) might help free up those rings.
Van was service last Thursday. #3 plug was replaced the week before that, and #4 was the week before that (what started this hole thing). So today I have filled the vehicle up with premium fuel, added fuel treatment, and pick up more spark plugs to swap. Now just waiting to order a disabler.
Replaced spark plugs, reinstalled muzzler, & did 2 rounds of techron in my gas tank back in mid-December to fix my piston issue - it's run like a DREAM since then. Yesterday, I notice my transmission shifting was a bit bumpy, and today I'm getting a "hot" smell. Any ideas what this could be? Maybe a transmission fluid flush/fill? Or oil change? I'm going to call my mechanic tomorrow, but wanted to pick the brains here first.
Never do a flush. A 3X drain and fill is often recommended. 3 1/2 quarts each time.
Why wouldn’t you have all 6 plugs replaced at the same time? I never have replaced just 1 or 2 plugs in 40+ years of driving. They are not that expensive.
How is the transmission fluid level?
Haven't checked it - I just looked up how to do it (I'm learning bit by bit how to do "car stuff"). I'll check it when I get home tonight after it's warmed up. I went ahead and scheduled with my mechanic next week for him to look it over, too - just in case. Thanks!
Discussion starter · #753 ·
This is not directly related yet to the VCM megathread on this forum, but I'm unable to figure this out so I'm coming to you guys for input.
I've revised the VCM megathread on Piloteers for the 2023+ Pilot with the new J35Y8 engine in it, and I'm having trouble deciding if the revised implementation of VCM warrants it being considered a new revision of VCM. It does deactivate only bank 1 like VCM-3 does, but since it has hydraulic tappets, it just depressurizes them instead of the old oil pressure solenoid approach with the varied cam lobes. I'm not sure if that's enough to warrant it being called VCM-4 or VCM-3.5 due to its similarity to VCM-3 otherwise, or if I should just group it in with VCM-3 (this is what I've done tentatively).
Appreciate any thoughts on this. This new engine is most likely coming to the 6th gen Odyssey as well, so it's not totally irrelevant here. Only forum out of the 3 that it's not relevant to is DriveAccord, since the V6 isn't coming back there.
VCM-4 or VCM-3.5
I would lean toward calling it VCM-4.
Granted the end result is still the same i.e. deactivation of bank 1 cylinders. Similarly, the new activation method of closing the valves using the new hydraulic lifters rather than the rocker arms seems inconsequential.
However, it's possible that the PCM VCM-related programming has changed e.g. different criteria for deactivating cylinders.
It's also possible that VCM-related engine mechanicals have changed e.g. piston or ring design or materials. After all, they did modify the GDI system, dropped VTEC, and switched the valvetrain to DOHC.
Based on the new VCM activation technology combined with the lack of detailed info about the J35Y8, I vote for VCM-4.
Reactions: WiiMaster
@WiiMaster any help here? Check emissions light came in on and I went to autozone to have them check codes. If you remember I have recently installed vcm tuner as well as had to get new alternator because of spool valve. I also happened to have oil changed a couple days ago. I had them clear the code for me, safe to drive? What should I do
Discussion starter · #756 ·
View attachment 173125 @WiiMaster any help here? Check emissions light came in on and I went to autozone to have them check codes. If you remember I have recently installed vcm tuner as well as had to get new alternator because of spool valve. I also happened to have oil changed a couple days ago. I had them clear the code for me, safe to drive? What should I do
That code is for the spool valve system, specifically the bank 2 spool valve that was worked on. This can be caused by a lot of things, including a bad oil pressure switch on the spool valve.
Discussion starter · #758 ·
Is it safe to drive? I should take it back to where spool valve was worked on then right?
If it's driving okay then it should be, sometimes this code can cause the engine to go into limp mode.
