Hi,
I am planning on pulling the intake manifold to clean out the EGR porting on my 2000 Odyssey LX. I have gaskets for the manifold and the throttle body.
I want to completely remove the manifold and clean it on the bench, but I get the impression, from reading about this process, that I will also need to clean ports on the top of the engine below the manifold. My question is what happens to the crud that I knock loose in the ports that are still in the car? Does the stuff fall down into the engine? Or can I blow the ports out through an outlet such as where the EGR valve is mounted?
I am comfortable with the idea of pulling the manifold but I don't really know what is below it.
Any tips?
Thank you.
Any tips?
Thank you.
