passenger side not driving side
When jacked up I've noticed I have a little play in the front wheel, when grabbing the wheel at 9 & 3 o'clock and rocking from side to side.
There isn't any play at all from 12 & 6, so I don't think this is my wheel bearing.
What is this usually indicative of?
Check the tie rods.
Do not assume no play 12 6 means all good(For a long time I did a check and all was good until I try prybar. and...lca was bad). Put a pry bar between hub assembly and Lower control arm to see if there is a play! Ody's suspension is odd and outer rods can look like lca and vice versa. Or could be a sway bar links.
