1 - 2 of 2 Posts
I just purchased a 2006 Honda odyssey. When we purchased the vehicle we were told that the power doors radio and DVD player did not work due to blown fuses when the battery and alternator went bad. Not a big deal, right! Easy fix, yes ... NOT!!!! Fixed the radio and the DVD player with the security code. Power doors and windows still not working. We have checked all fuses, and relays. Replaced a few fuses. Also replaced Driver side Kick panel fuse box due to no power to power window fuses. Still no power. The driver side window works. But passenger and both back windows nothing. You CAN hear them click when you hit the button on the driver side panel. Now for the power doors.... scan tool reads “B1163 And B1164 Lost Communication to power door module” Nothing happens with panel buttons or door handles.. When you close the doors manually they only latch in the front and gap open at the back of door NOT latching. Now when we clear the codes the only power we get is the door will suck in at the back (after closing manual) but only for maybe 10 seconds then releases again.
Did you try resetting the power doors... and also for the widows, did you pop out the controls and check to see if they are bad... we just bought some from pull-a-part and ours works great...
1 - 2 of 2 Posts
