If you have the wires going through a hole in the grommet so that it seals on the wires, you are probably fine - I'd seal it up with some silicone just to be sure, but you are probably fine as is. If, on the other hand, you removed the grommet altogether and just have the wires going through the hole, I would definitely seal it up. (I could probably get away with not doing anything here, since it's pretty dry - but in FL, I'd want it sealed if it were me.)
Agreed, except for the silicone part, it might make removal of the wire difficult in the future. Put some heavy grease on it instead, or rubber cement, or something that won't necessarily set up... :D
