1 - 8 of 8 Posts
Occasionally I will feel a slight “popping” coming from the steering wheel/column when turning, or braking. It’s not easily replicated so wonder if there is an underlying issue. Anyone else experience this?
Check for a leaking CV joint or axle, felt the same when my axle started leaking.
I had some popping when turning (to full extremes) to get into my garage. I was able to recreate it at the dealer and they replaced a lower control arm. I think I have heard it a few times after replacement, but whatever they did certainly helped. It would happen ever time I pulled in or out of my garage.
I can feel the same when I am turning. Its very minute and I cannot easily replicate it. Maybe I will bring it up with my dealer and see what they say.
Discussion Starter #8
To close the loop on this....dealer found the steering wheel cover was rubbing against the steering wheel. They adjusted it and I haven't noticed anything since.
1 - 8 of 8 Posts
