Passenger sliding door was closing and I stopped it with the remote 1/2 way. The door completely died (no power). Tried to reset it by sliding manually to each end and even took out fuse #5 on the kick panel hoping to reset the logic. No dice. Constant buzz while closed. Shut it manually and took it to the dealer. They took out fuse #13 to reset the door and cleaned the contacts. Fixed. What gives? The motor isn't powered by the contacts (since they aren't in connected unless the door is closed) and the description of fuse #13 (all of them) is not remotely connected with the slider. I want to perform this fix when I’m (again) far from the dealer on a Sunday. Insight is appreciated.
kreipe
kreipe
