Power sliding door mega thread - common issues, their symptoms, and how to fix them
1 reading
113K views 314 replies 84 participants last post by  usx21518
My problem is when I open the door it beeps three times but the door does not open automatically. Opening the door manually is no problem. Check the center roller or fuel door switch, no problem. I also tried unplugging the #7 fuse in the driver’s footwell fuse box for 15-20 seconds. The door just won‘t open automatically (sorry my English is no good)
Rubber bumpers, center roller, latch actuator, rear latch element, fuel door interlock, micro switch, all checked, beeps when push button is pressed to start, sliding door light on dash comes on, I've tried everything WiiMaster teaches. But sometimes I also try to unplug the No. 7 fuse in the driver's footwell fuse box for 15-20 seconds. The door would suddenly open automatically, but after a while, the sliding door light on the dashboard came on again. The error code checked is B2033. That's probably it.
Use a voltage meter to check all the micro switches. If I remember right they have BOTh kinds(normally open and normally closes) on the latch assembly.
Most likely one or more are not working correctly. They can be replaced individually, available on Digikey.
