I have a 2009 Honda Odyssey EXL that was purchased used less than a year ago. A few months after having the car the power steering started whining when it was cold in the morning but after a few minutes would stop. That went on for about a month and then it started whining at all times. I read forum posts about this problem and so then tried the easiest thing. I replaced the inlet and outlet hose o-rings with the updated versions but it made no difference. I then replaced the pump, inlet hose (with new screw type clamps), and reservoir. Still sounds just the same. No fluid loss at all, but bubbles in the reservoir. I have changed the fluid out until it was fairly clean but of course the air getting sucked into the system makes it dirty again. I have no idea where the problem is. My assumption is that if air is getting into the system it must be a leak in a low pressure area of the system. Am I right about this? Where should I look? Where does the low pressure area begin and end on this system? Could the leak be in the high pressure area?
Thank you,
Adam
Thank you,
Adam
