...with a $0.10 O-ring
My PS pump on my '99 was making whining noises on cold days (< 40F). After reading these forums, I checked for an air leak on the suction line. Replaced the O-ring on the suction fitting on the pump and problem went away. I just used one of the extra green O-rings I had left over from an AC o-ring kit. I hope it is compatible with PS fluid. The one bolt holding the fitting on was a l3i+ch to get at. I had to remove a bracket that was holding a wire to the alternator to get enough stroke on the 10mm combo wrench.
OT... I just ordered some Monroe quick struts and some KYB rear shocks for this beast.
