1 - 7 of 7 Posts
I have a 2003 Ody and we have a strange problem with the power controls for the passenger side window.
The controls for the passenger window on the passenger side door work fine. You can roll the window up and down, just like you should be able to do.
On the driver's side door control panel, you can only roll the window down, but NOT UP! I have checked the connections and fuses. All seem fine.
Has anyone seen this before. Do I need to purchase and install a new drivers side control panel?
I have the same problem except my passenger window only rolls up, but not down (from driver's side). Works fine from passenger side. I have replaced both the passenger and driver window switches, still won't roll down. Any luck yet with your window problem?
driver side window stuck
im having the same problem with my 04 , driver side window rolls down at times but will not roll back up !currently driving with the duct tape and bag over it ! if any one has any links or suggestion pleas post !
To this message:
Has anybody ever figured out what the cause is for passenger window failing to respond to the master switch in the down direction?
This is my second try at using the site, I am having problems with the passenger side front window on my 2002 Odyssey. Neither the master switch nor the passenger door switches will move the window. My first thought is do the switches ever fail or is it always the window regulators? Help!
the switches do fail (according to Honda "sometimes more often than actuators" which I guess make sense how something sometimes does something more often... but I digress) but I would check switches and actuators.
1 - 7 of 7 Posts
