Just picked up my 2011 Elite. When I set the Light Control Switch in the headliner to the Door Activated Position, the second and third row interior lights do not turn off when I close the door -only the first row lights turn off. I know it takes a little while for the lights to turn off, but they don't turn off even after several minutes. I have to turn the Light Control Switch to Off to turn off the second and third row lights.
I can't imagane there is a separate setting for the second and third rows vs the first row and I did not find anything in the owner's manual. Can anyone help? Thanks.
Jeff
You probably have the second row lights activated. Instead of using a switch, the interior light turn on and off by pressing on them. While it makes for a cleaner design, the negative is that they can get accidently pressed quite easily. It's already happened a couple of times to me because I accidently hit my head on them when exiting the second row.
:rollingeyes:
