1 - 7 of 7 Posts
2004 Ody.
150 k miles.
Michelin Defender tires with 5/32 remaining.
Planning to keep the vehicle.
One of the tires was losing air. Went to Costco. They said it had a puncture in the sidewall area so was not repairable. They suggested putting 2 tires on. I had them put the temp spare on until I can figure out what to do.
I generally like to do tires in 4's rather than 2's. That said, there is some life left in these tires at 5/32. So options include:
1) 4 New tires
2) 2 New tires
3) 1 Used tire??? I've never done that before. But could buy some extra time. I know the tread depth would need to roughly match. Would it also need to be a Michelin Defender tire?
Thanks for any input!
This happened to me before on my old ody. I tried the 1 used tire. Bad idea. It messed up other tires. Then what I did was to get 2 walmart cheaper, softer tires. So, replace 1 tire with cheaper new tire from walmart or sears. Suggesting softer so that it wears out sooner and it might even match others when close to 2/32 ....
As for the tread pattern, it is supposed to be the same for 2 tires on 1 axle. But defenders are non-directional and those walmart tires are pretty close.
The used tires were $30. It looked ok but somehow balancing was off. You might end up with bunch of extra work.
Replacing just 2 tires is definitely a viable option, but you would not be able to rotate them to the other axle. So that makes this only a short-term option.
Since you are planning to keep the van, I would go all the way with a set of 4 new tires.
What's the manufacture date on the tires? They are considered expired at about 7 years. If close to that, they have less life left than the tread wear would indicate.
You may succeed in recovering some of the cost by selling the old tires.
Dave
Maybe it's just because I think almost anything is possible if you do it right, I'll say that any of the 3 options can be made to work well. I've done them all.
For option 3, just make sure you get a quality single used tire, not a craigslist freebie.
With 5/32 left. NO brainier. Buy 4 new Michelin's at Costco. You should ask them, when is there next sale.
Cannot beat the price. If the sale is in a coupe of weeks, wait. If not, pay the extra $100+. And be gone. :)
+1 for 4 new tires. Maybe you live where it never rains or snows, but 5/32 is my personal limit. Too much lost traction on wet or snow covered roads. If none of that applies to you then you just got your next tire purchased pushed up a bit, but not by that much.
I would replace all 4 tires. I bought at Costco and asked to use Michelins since that is what I had been using. They recommended Bridgestone for the Odyssey which also were about $100 less. In the end I did go with the Bridgestone ECOPIA EP422+ Grand Touring A/S with the 70,000 Mile Warranty. They actually run smoother and quieter than the Michelins. Make sure to have them rotated (free) every 5,000 miles. Vans are tough on front tires.
1 - 7 of 7 Posts
