so my 99 odyssey is being a real pain. Battery and alternator test out fine. Radio and gauges randomly turn off and about 15 seconds later it turns back on, but is still running. Started happening yesterday. Got it home and went to restart it and it cranked then did a rapid click click click like battery died. About a hour or so later it started and drove fine til it turned dark. Then it happened again. It’s like it died while driving but it still is running when that all happens. I need some insight on this. I don’t want to start taking things apart when it could be simple.
Had this happen on our 2004. It turned out to be a loose cable at the battery. Tightening the cable fixed it.
Also check the battery ground connection to the engine while you're at it. My '99 cable was very frayed.
