No, it does not.Does the rear A/C on a 2006 have it's own filter? If not how do I access the evaporator to clean it out, after 5 years of carrying out golden retreiver to work and back every day I am sure the rear evap or filter is full of dog hair![]()
I think the "easiest" way would be to remove the blower motor and vacuum anything you see, but even then it won't be easy: It takes some time to remove the rear trim panel and the evaporator is right below the blower, so not sure how much access you'll have. Otherwise, you'll have to take the whole assembly apart...
Nicolas
