Does the rear A/C on a 2006 have it's own filter? If not how do I access the evaporator to clean it out, after 5 years of carrying out golden retreiver to work and back every day I am sure the rear evap or filter is full of dog hair
I think the "easiest" way would be to remove the blower motor and vacuum anything you see, but even then it won't be easy: It takes some time to remove the rear trim panel and the evaporator is right below the blower, so not sure how much access you'll have. Otherwise, you'll have to take the whole assembly apart...
I dont think thats possible. If I were you I'd ask a mechanic (NOT A SERVICE REP) at the dealer to be absolute. But from what I can tell, there is no air intake in the rear for dog hair to enter and the only way for it to enter from the front is during when recirc is on.
You are right that there is no outside air intake, but there is an internal intake in the rear side trim, across from the spare tire (the back is always on RECIRC...). Dog hair could go in, I guess.
If you find a lot of hair in there you *could* rig a home heating filter behind the openings in the rear trim panel, to catch them before they get to the blower. They have very "free- flowing" filters that should catch the hairs without blocking the air.
It is called the "Rear Air Outlet" in the service manual, and the section covering its "replacement" is in the AC section of the manual. I just put 2 and 2 together...
The vent in the rear left lets air out of the van. You need this when running outside air and for closing doors, otherwise you will build pressure inside. In the HVAC business we call this a relief vent.
The rear blower & evaporator is located on the right side and only sucks air from the inside. No need to pull from the outside as you get plenty of ventilation from the front. Also if the rear ac pulled in outside air, it is so close to the tailpipe you would have a big chance of pulling exhaust inside!
This is why I have a carbon monoxide detector in the back. I want to know if my kids are breathing in poison! It has shown small readings occasionally. The last time I pushed "peak" on it, it showed 23 ppm? Not sure what that number means but it is safe for short term. Probably got some exhaust in there while the engine was running in the morning with the lift gate open. Now I wait til the gate is closed before starting a cold engine.
The rear AC on my '07 EX-L definitely does not have a filter and does not take in outside air.
I took off the trim panel to perform the "rear 12V always-on" mod. While I was in there I cleaned and checked out the AC. I've been concerned for years about dog hair and other nastiness getting into the rear AC. My worries were fully realized today.
The blower is about 18" above the top of the carpet. It pulls in air from a space inside of the body panel. Air comes in through the louvers in the trim panel just above the carpet.
It is not immediately clear how to clean the evaporator. I think I feel screws which hold together the plastic evaporator + blower assembly, but they face in towards the body panel.
Taking out the assembly would involve the refrigerant lines...
Here's a diagram of the blower + evaporator assembly showing how to access the evaporator for cleaning imgur: the simple image sharer
I was able to reach my arm through the blower outlet and pull out almost all of the hair and lint in one sheet. imgur: the simple image sharer
Here's the evaporator almost completely clean. I got the rest of the hair out with a toothbrush. I sprayed the evaporator with 409 until it ran out of the condensation drain. imgur: the simple image sharer
I found some cuttable AC filter at the local Ace for $2.50. The 15" width is just right; I cut it to 10" high. imgur: the simple image sharer
FYI, your "sensor" in your diagram is the blower motor resistor. It determines blower motor speed. BTW, nice write up and a great preventive maintenance item. Adding to my "TO-DO" list.
