My AC stopped working so my husband noticed a small rock hit the condensor. He replaced it, had the unit recharged and everything seemed ok, except when it's really hot out, we turn the rear ac on and then it blows only hot air and causes the front to do the same. If I shut the unit off, then only put on the front ac, it works fine. The only time there is an issue is when the rear ac is turned on. I checked all the fuses. Any idea on what is happening?
Also, husband had the pressure rechecked for the freon so it's not short of any and also checked for leaks and there doesn't appear to be any. Thanks
