1 - 2 of 2 Posts
Hello all,
I just did a rear brake job on 07 Ody with OEM pads/rotor and have a few questions:
1. Is the packet included in the OEM rear pads to lube the slide pins? I'm a bit nervous that that was anti-squeal. I lubed the slides with it.
2. I ripped a slide pin boot lubing the slides. How critical is a replacement?
3. Are the rear torque specs really: Caliper pin bolts 16 Lbs/ Caliper Bracket bolts 65 Lbs./ Wheels 94 Lbs.? They're much less than the fronts.
Any help is appreciated to put my mind at ease,
Mark
Discussion Starter · #2 ·
Edit
I need to dope slap myself. All of the info was on the forum. Sorry - noob mistake. I will be pulling the rear brakes off, cleaning the wrong grease off, and using proper slide lube. I also bought and am replacing the slide pin boots. Live and learn.
1 - 2 of 2 Posts
