There is no proper gardget to re adjust rear/backup camera for my 2019 odyssey even in official service center in Korea.
Can anybody guide me how to calibrate rear camera guideline setup with diy-way?
If it is not easy to do it by myself, then I really want to know all the set-up numbers of your car cause I lost my factory setup numbers during my tests.
please share your know how or setting info. (you can take photos of your set up and send them via email [email protected])
153779
153780
153781
You can access a Dealer mode if you press and hold [HOME], [Screen Brightness] & [VOL/Power] for several seconds. A "Dealer Diagnostics" screen will pop up and select DETAIL INFORMATION & SETTING. There you should find REAR CAMERA GUIDELINE SETUP. I've never messed with any of those settings, so use at your own risk.
154216
154218
154217
If you're feeling adventurous, If you press and hold those three buttons again, you'll open the "Developer Diagnostics" screen with even more options.
