Can anayone tell me how to change the rear coil springs . Do I jack it up and drop the shocks . Do I do much else ?
I need to know as my 2 rear springs are broken .
Replacing the rear springs is a 1-bolt job - the lower shock bolt. See post #5 in this link for a good picture. This is a newer model, but yours is similar.
Broke as in...the coils cracked? No kidding?
I wonder if the rear springs on our Ody's are too weak? I remember a post where someone had added helper air bags. I sometimes feel like I could use a little more tension back there myself.
In addition to the rear coil springs, I installed the Monroe Load-Adjusting Shock in the rear as well. Basically an extra coil spring around each shock for added lift. Or you could use the airbags.
