1 - 2 of 2 Posts
Hi,
We have a 1999 Odyssey, and when I got home today I noticed that the rear corner on the driver's side is sagging substantially. The distance between the tire and the tire well is at least 2 or 3" lower then the other corners.
Any ideas? I'm guessing we need a new spring, but I'm not sure... Any advice would be greatly appreciated!
Thanks,
Chris
cclay, do they use salt on the winter roads in your area? If so, you may actually have a broken spring. I've heard of broken front springs on these Odys, but not rears...still, anything is possible.
Take a peek. If it is sagging, it may be time for new springs. The rears are much, much easier to replace than the fronts.
1 - 2 of 2 Posts
