Hi, I just got a brand new Odyssey 2022 and the rear fan will only blow on the feet and will not change to blow on the face.
It’s under warranty, not something we’d crack open To try and fix.
Are you sure you selected rear controls to change it independently from the front?
Yes I adjusted all controls as needed.
I have an appointment with Honda services in about three weeks so was wondering if its a common issue that is easy to fix, otherwise I'll obviously not touch it as I don't want to void the warranty.
thank you.
