What problem did you have with your rear vent windows?
  • Bad motor fixed under warranty
    Votes: 40 8.1%
  • Bad motor fixed NOT under warranty
    Votes: 60 12.1%
  • Bad motor not fixed
    Votes: 227 46.0%
  • Had different problem (please elaborate by posting below)
    Votes: 18 3.6%
  • Had more than one problem (please elaborate by posting below)
    Votes: 12 2.4%
  • Never had a problem
    Votes: 154 31.2%
  • Total voters
    494
1 - 20 of 146 Posts
Have you had any problems with your rear windows malfunctioning (including warranty repairs)? Let us know...
My driver's side vent window will only open about half centimeter and that too only sometimes. If it opens at all, it has a hard time closing. My passenger side vent seems to work ok. I have hardly ever used my vents. I have a 2002 Odyssey with 40000 miles.
I have noticed recently that both vent windows work intermittenly. Have not had them examined yet.
I have 2000 Ody. The passenger side Vent only opens little bit and then stops. After a couple of times try to open, it sops all together.
1999 LX. Approximately 140,000 km.
Passenger front window has developed a relationship with the passenger side vent.
When closing the vent, the front window slides down smartly.
So closing the passenger side vent is a two step process. Close the vent and passenger window opens. (Quite fast). Then close the passenger window. Unless you want to leave it open.
The relationship is totally one-way. Opening or closing the passenger's window has no effect on the vent. Which is good otherwise we would have the makings of a black & white man-against-machine comedy.
Perfection is asymptotic.
2000 EX, 110K miles, vents still open and close fine, but they make an awful sound like fingernails on a chalkboard when opening and closing. Been that way since we purchased with 60K miles.
My experience is identical to EricW's. Your description of nails on a chalkboard is PERFECT! There's no apparent easy way to get to the mechanism to lubricate them either.
No problems with the motors. However, my daughter (who sits in the back) tells me they leak a bit in the rain.
-Stew
My passenger side window rattles (although the dealer didn't seem to hear it while the van was still under warranty :mad: )
Other than that they are working fine.
Wife never uses them, I do on nice days and to vent the hot air in the summertime on startup. Best guess, 200 cycles per year. Four years on the 03 is 800 cycles, not much of a test.
'99 LX 114,500 miles:
Nothing wrong with the motors, but drivers side vent came half-way unglued. It was only being held in place by the mount in the back that attaches to the motor! Anyways I noticed it making a scraping sound once. Checked it out and as I opened the vent the window would open and also pull away from the top.
Took to friendly body shop and they re-glued it for me no problems. Said it is common with windows like this that pivot open.
When its hot, the left rear window will stick open. I have to wait until the temps cool down.
1 - 20 of 146 Posts
