The camera is right above the license plate on the passenger side. Did you check the camera to make sure it's not loose? I don't think there is an adjustment, so I'd suspect it just got bumped or something.Does anyone know how to adjust rear view camera on '08 Ody? The camera is out of alignment. Thanks in advance.
Thanks for the reply. I've checked camera and it's secure. The camera is not loose and you cannot bend back into alignment.The camera is right above the license plate on the passenger side. Did you check the camera to make sure it's not loose? I don't think there is an adjustment, so I'd suspect it just got bumped or something.
