Any tips or tricks on reving the tension on the rear wiper? Can you replace the spring? If so, where do you get it? The tension seems pretty wimpy, and doesn't wipe too well.
Thanks
You should remove it and clean all the pivot points good as they get jamed with salt and dirt. I clean them with WD40 and then lub with spray silicone. WD40 does not lubricate and do not use regular grease or a grease type silicone. Just spray silicone.
