I have a 2000 with remote entry, alarm system and the GPS.
I assume it is possible to have the remote entry without the security system. Is that a correct assumption?
If so, where is the receiving antenna for the remotes and where is the magic box that makes the thing work?
My problem is clearly temperature related. The remotes (3) will only work in the morning if you are within 2' of the car and try multiple times. After about 10AM when the outside temperature here in San Diego is usually above 60F, it will work from 100' away.
All remotes act the same way, so I am sure it is vehicle related. I would like to start with the receiving antenna location and clean all connections involved.
Where do I start? Thanks for the help.
