Like to know how to remove the third row seats instead of just lowering them into the floor recess. Thanks
The challenge is to make a proper lid for the well and to find upholstery that matches. I have done this and i can send you pictures if you wish.
Eric
The 3rd row folds flat, I wouldn't have gone to the hassle of removing it permanently, especially since you had to go through the pain/expense of making a lid cover for the well...ok...We permanently removed the third row seat in the last three Honda vans we have owned. The 2011 is the easiest. The covers for the hinges split apart and then it is very obvious that you just take out a bunch of bolts. The challenge is to make a proper lid for the well and to find upholstery that matches. I have done this and i can send you pictures if you wish. I am leaving tomorrow evening for four days but will be back next Wednesday.
Eric
So can only one side of the seat be removed? The bigger side and the smaller one seem to be connected together. Did you have to remove them as one whole unit or one by one? I looked at the cover and was not sure of how to split the cover open. Also I wonder how easy they can be put back later on as they are spring loaded...:huh:...The covers for the hinges split apart and then it is very obvious that you just take out a bunch of bolts...
Eric
Orville, I want to remove the third seat of my 2003 Odyssey - have you done it, and any advice? ThanksWe permanently removed the third row seat in the last three Honda vans we have owned. The 2011 is the easiest. The covers for the hinges split apart and then it is very obvious that you just take out a bunch of bolts. The challenge is to make a proper lid for the well and to find upholstery that matches. I have done this and i can send you pictures if you wish. I am leaving tomorrow evening for four days but will be back next Wednesday.
Eric
Check out this from the service manual.Orville, I want to remove the third seat of my 2003 Odyssey - have you done it, and any advice? Thanks
