1 - 2 of 2 Posts
Sliced front-"drivers side" ABS sensor's wire when strut's coil broke. Replaced struts/coil/endlinks and applied elec. tape on ABS wire thinking I could save it.
ABS light is now "ON" so wondering how difficult is it to replace this sensor. Have not called the local Honda dealer to determine the cost while project it will be totally inflated.
Did you reset the abs code after taping the wire. Not totally sure but it may not reset by itself. It doesn't get reset by OBDII tester.
1 - 2 of 2 Posts
