1 - 1 of 1 Posts
Edit:
Never mind. The 16x49 does not refer to the bolt head, silly me. I just put a 19mm socket on the bolt and it fits nice and tight, so it's still a 19mm bolt.
Doh!
Previous text:
I ordered a new timing belt and a host of other related parts (water pump, idler pulley, adjuster, tensioner, etc.). For good measure I also ordered new bolts for everything. The replacement crankshaft pulley bolt is part #90017-RJA-003, which is listed as a 16mmx49mm bolt. However, the bolt on the engine is 19mm. Did Honda change the bolt size for replacement bolts? If so, why? I'd appreciate any insights.
(Look under 'PISTON - CRANKSHAFT', part #15.)
Link
1 - 1 of 1 Posts
