1 - 10 of 10 Posts
Honda dealer tells me all 3 engine mounts and both transmission mounts need to be replaced. Can anybody recommend a kit with all 5 mounts? Also, will replacing these help a frequently rough shifting transmission?
5? there are 3...
Front, Rear (transmission) and Right.
no kit..
stick with the beck/arnley
5% discount code.
Rockauto shows 5 mounts for 1999-2004 Ody.
They have 3 kits of all 5 from Westar, SKP, and DEA / MARMON
161753
Honda lists five mounts, four of them with the word "rubber" in the name. And the one without the word in its name---when you look at the pic at Rock, it's clearly got a big chunk of rubber. Honda mounts
Have same problem with mounts and shifting. Following.
What did Honda quote you for parts and labor?
1 - 10 of 10 Posts
