another supplier
I went to buy a remote replacement from Keyless Ride and the price had gone up ten bucks. I found another supplier of the OEM remote at
www.autotechs.com for $60 plus $5 shipping. I ordered it on Thursday or Friday and it got here Monday.
The intructions were not great but I found them on the forum courtesy of nemogira. These are his intructions that worked for me (though it took a couple of times and remember to program your old remote too as its code needs to be reentered or something).
NOTE: It is important to maintain the time limits between steps. Make sure the doors, the hood and the tailgate are closed.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 sec., push the transmitter lock or unlock button
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push transmitter lock or unlock button with the transmitter aimed at the receiver (control unit)
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver (control unit).
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver (control unit)
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec., aim the transmitters (up to three) whose codes you to store the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation with the transmitters.
