Caliper piston when pushed in does not "pop" back. When you press them in you have hopefully opened the bleeders forcing old brake fluid out into a container. There is no pressure to push on the pads until the brake pedal is pushed. Using this method you have to top off the fluid in the master cylinder but it's better because you are replacing the most worn fluid and adding new. I prefer to completely bleed with the pad change.
If your rotors are undamaged and the brakes work smoothly then turning the rotors is not needed.
Get a quality ceramic pad. I like the Akebono Proact, others have had good success with the Centric Premium. The Honda OEM are not that great.
