What does the fluid look like? Black? Pink?
Welcome to the OdyClub.Hey Folks,
I`m new to the Odyssey world with my 2010 Odyssey that I bought about 3 months ago. She has 160000k miles in the clock and since I have no records of the ATF ever changed I guess it`s time to change it. On my prevoius car with automatic transmission (which was a SAAB) I changed ATF by pumping out the fluid from the entire system using the transmission`s own oil pump. I simply disconnected the return line from the cooler at the tranny and drained off all the fluid while constantly topping up the system while the engine was running at idle. It took like 5 mins until I observed the clean fluid leaving the cooler indicating the whole system is flushed with new fluid. I looked around the web and this forum but I couldn`t find a detailed description of this method. So, I thought I ask around before I start exploring myself if there`s a DIY for this. Thanks!
Last time I looked at the didpstick it didn`t look bad.What does the fluid look like? Black? Pink?
Thanks, I`ll look into it.Well. Search and read up. Hoards of debates on that here. Good luck with the searching and reading. It’s a LOT to go through.
Don’t do this.Hey Folks,
And Honda's transmission is also unique, like no other manufacturer's. So I tend to stick by what they've outlined. Other manufacturers also say their fluid is good for 60k, sometimes even 100k. Honda ATs are different.this is completely different and many other enthusiasts do that on their cars, including Japanese brands.
Then do a single drain&fill now, and the next 30k miles later. Some folks do it every other oil change.Last time I looked at the dipstick it didn`t look bad.
Did you remove the drain plug during your procedure, if not , highly recommended to remove and clean the magnet every ATF change."why deviate from what Honda has outlined?" Because I don`t understand the reasoning behind it.
Using the ATF cooling circuit line is an even bigger “waste“ of fluid.... I don`t see the reason why Honda does not recommend this, it does no harm to the transmission if done properly. On the other hand, draining the fluid 3X is a huge waste and not too eco-friendly.
Issue with your method would be that it MAY just replace SOME of the ATF and not all ATF since ATF does not necessarily will be flowing from all locations until the tranny is engaged and can't do that unless you are actually on the road and moving."why deviate from what Honda has outlined?" Because I don`t understand the reasoning behind it. Unless it`s because Honda does not want the user to mess with the cooler lines because if they screw up something they will point at Honda that they were just following their guidelines. Instead, they make the user buy the Honda specific fluid 3X more than necessary, it certainly makes some profit. I would do the same. Sorry, I just like questioning the status quo, especially if it makes no sense. Again, I understand the reasoning for not recommending power flushing the system that some shops used to do, but this is completely different and many other enthusiasts do that on their cars, including Japanese brands.
On transmissions I`ve worked on (Aisin) that`s not the case and almost the total volume including the converter can be drained. Some oil channels of course remain unaffected, those that belong to dormant functions, but that`s negligible compared to the volume of the converter and the heat exchanger. I don`t think this transmission should be very diferent from an Aisin, but i`ll take a look, thanks.Then do a single drain&fill now, and the next 30k miles later. Some folks do it every other oil change.
I think the reason your direct method to pump out the old and fill in the new won't work is that the fluid in the torque converter doesn't move until the TC locks up at highway speeds.
Somebody recently resurrected a thread promoting your Saab method- think it might have been in the 2nd gen section.
Yes, good point, I was gona include that as well. I`ll start with that and inspect the drained ATF.Did you remove the drain plug during your procedure, if not , highly recommended to remove and clean the magnet every ATF change.
You will get about a teaspoon of black sludge along with metal shavings.
Thanks, I`ll take a look at the circuit diagram. Again, this works well in Aisin transmissions and replaces the used ATF efficiently in the converter, the heat exchhanger and the related oil lines, which is a huge mass of fluid.Using the ATF cooling circuit line is an even bigger “waste“ of fluid.
If you have a Helm Publishing Honda Odyssey shop manual, look at the ATF pump / torque converter clutch / cooling circuit diagram at the beginning of the transmission service section. Disconnecting a fluid line from the cooler results in missing all of the fluid from the torque converter clutch and its clutch proportioning valve fluid pathways. That's quarts of fluid that don't get removed. You're essentially only removing ATF from the sump using that "technique" ...
... draining the sump by simply removing the drain plug gives the same result with less fluid waste.
Removing an ATF cooler line is just extra work to no extra result. Just drain, refill, drive van through all gears up to torque converter clutch lockup, go home, drain again (and repeat, repeat if you're doing a 3x drain/refill because you bought a van with an unknown service history).
Pulling a cooler line is just "re-inventing the wheel"... except, it's a square wheel.
Depending on the easyness of this job I`ll test all scenarios and see what the outcome will be. Again, the mass of fluid that remains in the torque converter and the heat exchanger that you deal with when you just drain the ATF is not comparable to the volume that remains in the oil channels of belonging to dormant functions. Maybe Honda is different. Maybe the best is to combine both methods, one full drain of the sump, refill, then cycling the fluid through the cooler line. That`s still a much better flush then just draining ATF 3x IMHO.Issue with your method would be that it MAY just replace SOME of the ATF and not all ATF since ATF does not necessarily will be flowing from all locations until the tranny is engaged and can't do that unless you are actually on the road and moving.
Now, your method may just work if you do it 3x. Like do it once, drive around do it again and drive around and do it 1 more time. Pretty easy to check IMHO whether your method works well - do it, drive around and work all gears and then drain again to see if the ATF still looks clear and red, if so, then your method works well, if not, then you KNOW it did not drain all old fluid. Also, ATF drain bolt has magnet which is supposed to trap the metal shavings that you won't be able to clean off if you use your method.
Also, I am in team "Valvoline MaxLife" when it comes to ATF (not DW1 like most guys here swears by). Cheaper to boot and worked well for me. (the jerky shift is gone and I did use DW1 before).
