2000 Ody, P0420 and EGR code, 180K miles, blah blah blah.
Doing the CAT and O2 sensors, I know about ordering direct from Denso to save money. As far as ordering the CAT, though, I'm not sure if Eastern Catalytic or Walker are worthwhile companies. If you were to order an OEM fit cat, but you can't afford the $500 for the actual OEM cat, which would you purchase?
Has anyone here used the Eastern Catalytic or Walkers with good luck?
EGR question: Do I just swap the EGR and gasket or do I have to clean anything when I do it? Also, how tight should it be? Regular tight or is there a torque rating that I should use?
Thanks!
Thanks!
