I have a 98 Odyssey with leather seats. The driver front has seen better days. I looked up the company that provided the leather covers to the dealer and they want $275 for one cover.
I found a set (2 fronts) from a 2010 Odyssey for $225 and was wanting to know if anyone has swapped seats or even know if this is possible? I have no problem making brackets work or welding if necessary to make them work.
What do you guys think? :huh:
I would measure the width of the 2010 seats to make sure the 98 is wide enough for them. You want the centre of the seat to be in line with the steering wheel. You also need space between them for the shifter.
The '98 shifter is up on the column. No problem there. What you will run into is hitting up against the emergency brake handle.
