I wonder if anyone can tell me what Helm says is the correct procedure to reset the PCM/ECU, I believe this is also called the learned idle procedure.
I am finding two different set of instructions on the internet.
After disconnecting the ECU fuse and waiting 5 minutes;
one sets says to start the engine without touching the gas pedal and let idle for 5-10 minutes - this presumes a pre-warmed engine, then take a above 40mph trip for about 30 minutes.
Another says to start the engine and maintain idle at 3K until normal temp (2 radiator cycles). Then let idle for 5 or more minutes.
I don't believe my Ody was properly set by the dealer, owing to poor mileage (a overy rich mix) and I want to try a correct fresh start.
