Hi all,
I've got a roof leak that I've not been able to find an answer to.
I've got a 2012 Odyssey with about 200,000 miles on it. Recently, we started seeing moisture in the headliner between the roof instrument cluster and the windshield near where the rearview mirror is mounted. Moisture is only felt during hard, driving rain at highway speeds. Thinking it might be a windshield problem, we took it to Safelight and they told us that the windshield was fine and that it was an issue with the sunroof drainage tubes. So yesterday I check the tubes and found that the driver's side drained freely and the passenger's side drained more slowly but still drained. Regardless, I can't resolve in my head how moisture that should be draining via holes in the corners could result in moisture in the center front, which is physically higher than the sides and where I don't see moisture in the A-pillars.
Any thoughts as to what I'm overlooking here?
Thanks for your thoughts and advice!
John
John
