Debating on getting these. I probably would only use the cargo box if anything. So my question is should I get these for the "just in case" factor and if so is it worth it to have the dealer install them. Is there drilling involved??
Check out instructions for roof rail installation here: http://www.bernardiparts.com/Images/Install/2011_Odyssey_RoofRails_AII43928.pdf.Debating on getting these. I probably would only use the cargo box if anything. So my question is should I get these for the "just in case" factor and if so is it worth it to have the dealer install them. Is there drilling involved??
Excellent point, my friend. Honestly, I had Thule load bars and was hoping Thule would have a fit-kit for the 2011 Odyssey soon; and so did not order the roof rails with our EX-L. Unfortunately, our need for carrying additional things on the roof may come earlier than Thule can have their fit-kit ready. So, I’m now considering putting the roof rails on myself.If you dont think you'll really need them, dont put them on. Every external accessory you add will have some effect on fuel mileage by affecting the aerodynamics, and roof rails may cause a slight added wind noise issue.
Thanks for confirming the seal between the feet of the rails and the weather-stripping! It wasn’t clear from that dealer’s video just how much of the weather-stripping would be “clamped-down” by the feet (meaning, how much of it would be under the feet) once installed. Good to know.the seal is not bad...the issue was getting the weatherstripping back into the channels as tight as it was before. To install, you have to cut the stripping into 3 sections then the feet of the rack hold it down. My weatherstripping is a little loose but not as loose as the weatherstripping on the Ody with a rack I saw at the dealer:rollingeyes:..on another note...After I installed the rack I noticed a rattle in the van. It sounded like it was coming from the vicinity of the spare tire (I had pulled out the jack to take of the rear wheels to install mudflaps) turnss out it was loose bolts on the cross bars. Dealer tracked it down and fixed it. No charge!:nice:
I disagree, I think the van looks much better without the roof rack. I never used it on my previous 3 vans and don't now. The van's handling gets effected changed by the weight/items on top, as well as the highway gas mileage. It's much easier to clean the roof off when it snows compared to my 2005.Van looks much better with the roof rack so I say install it. Should have come with roofrack and body side moldings standard...
I bought the crossrails for my '02 and NEVER put anything on the roof in 8 years of ownership. I was ready to buy a box but glad I didn't, would have never used it either. Of course, I only have a family of four which allows me to pack a lot of stuff in the back. If you need the third row then I could see the need for using a roof rack at times.I disagree, I think the van looks much better without the roof rack. I never used it on my previous 3 vans and don't now. The van's handling gets effected changed by the weight/items on top, as well as the highway gas mileage. It's much easier to clean the roof off when it snows compared to my 2005.
Here in NJ it's a $50 fine if you don't clean your roof of snow, which I agree with. I see so many lazy people with SUV/Van's. that don't clean it and flies onto other cars...
