If the battery was disconnected as part of the repair, you need to do the idle learn procedure:
Do the Idle Learn Procedure
To ensure a steady engine idle, do the idle learn
procedure:
1. Make sure all electrical items (A/C, audio unit,
defogger, lights, etc.) are off.
2. Start the engine, and let it reach its normal
operating temperature (the cooling fans cycle
twice).
3. Let the engine idle (with the throttle fully closed and
all electrical items off) for 10 minutes.
The idle learn procedure must also be done after
updating or replacing the PCM/ECM. It does not need to be
done after you clear DTCs.
procedure:
twice).
