We just bought an '03 Ody (SSM EX-L RES) and I've noticed that the rubber around the sliding door seal is wearing down on the driver's side on the lower left side of the door. The van is only 6 weeks old. The seal looks to be put in correctly. Has anyone else had this problem?
Thanks!
0
Guest
Yes, I had the exact same problem! It was indeed installed incorrectly. Dealer ordered a new part and problem fixed:) .
I've noticed the same type of wear on both sides of my 03 EX. When you say the seal was installed incorrectly, what specifically do you mean? I need more details before I contact my dealer.
Thanks,
Mark
Minneapolis, MN
0
Guest
If you pull-up on the seal at the point of wear, you'll notice the seal not being seated properly on the metal lip (the underside of the rubber seal was slightly folded-over and pushed-on and not seated properly). Hope this helps.
