Nope. As long as there's no fluid on it you're gold.
Thank you. What is the panel / what is it for?Nope. As long as there's no fluid on it you're gold.
It is an access panel you can remove when taking out flexplate bolts or turn the flexplateThank you. What is the panel / what is it for?
Thanks very much, I appreciate it.It is an access panel you can remove when taking out flexplate bolts or turn the flexplate
Thanks!Yeah, that's the cover for the torque converter bolts. Worst case scenario it is replaceable.
